Quick L-system Question
The l-system help describes two methods for "edge rewriting"...
Premise F(1,1,3,3,0)
Rule 1 F(i,j,k,l,m) :m=0 = F(i,j,k,l,0)+F(i,j,k,l,1)+
Rule 2 F(i,j,k,l,m) :m=1 =-F(i,j,k,l,0)-F(i,j,k,l,1)
Which gives a nice transition between generations, but is quite long to write out, and:
b ch("generations")
Premise l
Rule 1 l:t<b=l+r+
Rule 2 r:t<b=-l-r
Rule 3 l=F
Rule 4 r=F
Which is much simpler to write out, but doesn't transition between generations, instead it shrinks towards the origin and then suddenly jumps to the next pattern... also I don't understand how the first part (l:t<B) works/what it means.
Is there a way to get the effect of the first method, but so it is simpler to write like in the second method? I'm new at l-systems so please keep it simple (if possible)
(EDIT) I skimmed a bit further through "algorithmic beauty of plants" and it seems like edge rewriting is abandoned for a while...
Edited by kai.scorpio
  • 1 year later...
I have the exact same question (I suspected that someone else might have asked it). I'm sad to see there were no replies. I can answer that the code t<b tests the current generation against the final generation, I assume so that the rule will not match on the final generation. I too would like to use the simpler syntax, as suggested in the help, but unfortunately it does not seem to work.
anybody ?
thanks
-ranxx
b ch("generations")
Premise l
Rule 1 l:t<b=l+r+
Rule 2 r:t<b=-l-r
Rule 3 l=F
Rule 4 r=F
Hi folks.
I just copy/pasted this from the help section:
F(l,w,s,d) Move forward (creating geometry) distance l of width w using s cross sections of d divisions each.
The example is:
m is a variable introduced to set conditions with
Erik
Edited by Ezz
yes, this works, but it is ugly, and doesn't look like the code from the book. The question is why doesn't the second formulation in the help work.
-ranxx
Hi folks.
The example is:
Erik
