sipi Posted April 7, 2025 Share Posted April 7, 2025 Hello I'm confused into color management. Can someone sort this out? I have Blackmagic Raw footage. In Davinci Resolve it is looking fine. I use ACES and sRGB Output Transform. (As far as I know I have to use Output Transform according to my monitor. I have DELL P2319H monitor and I assume it is in sRGB, not Rec.709, but correct me if I'm wrong about this.) Now I want to export this footage, to use it in Houdini/Nuke. I turn off any Output Transform for exporting the exr sequence. It looks like this in Davinci: At this point I'm interested in getting the same image in Nuke and in Houdini what I have in Davinci. In Nuke, if I set the Input Transform to ACES - ACES2065-1 on the Read node I get the same image, which is cool. See: The problem comes in Houdini. First of all, am I right that Houdini 20.5 doesn't require ACES installation? As far as I know it has ACES built in. ...right? I bring in the sequence and something is off. The colors are strange. See: Do you have any idea, what is going on? What should I do? Regards, Attila Quote Link to comment Share on other sites More sharing options...
sipi Posted April 7, 2025 Author Share Posted April 7, 2025 (edited) Anyone who's interested, I managed to find out that I have to convert the images like this: (e.g. using Houdini COPernicus or Nuke) (in the Write node you can choose Utility - Linear - sRGB as well) Or! You can save this step by setting ACES Output Transform in Davinci to sRGB (Linear) - CSC at export. Probably this is the easiest way. Best wishes, Attila Edited April 8, 2025 by sipi 1 Quote Link to comment Share on other sites More sharing options...
Luxor9500 Posted August 20, 2025 Share Posted August 20, 2025 Hi there, That's correct in Houdini 20.5 ACES is already built-in. You can find the settings under Edit → OCIO settings. There’s also an explanation there about how different files are interpreted. For example, if the filename contains ACEScg, it will be interpreted as ACES, but I’m not 100% sure about this — I thought it was reading that from the metadata. That’s probably why, since you exported an EXR, it’s being interpreted as Linear sRGB. Whenever I want to make sure a plate is in ACES, I export it from Resolve and choose ACEScg as the Output Transform. That way I know it’s ACES in all applications. I also include it in the filename and make sure it’s saved in the metadata. This works for me, but if someone has a better or more technically accurate explanation, I’d love to hear it. Cheers, Kamil Quote Link to comment Share on other sites More sharing options...
