GlennimusPrime Posted April 13 Share Posted April 13 I haven't had luck using these path expressions in Solaris. Are these not supported in the USD workflow? Example: if I have a prune node directly after the asset I'm wanting to prune, is there a path expression I can use in the Primitive Pattern field, similar to what I'd normally use in Houdini? Quote Link to comment Share on other sites More sharing options...
