Daniel Posted October 1, 2007 Share Posted October 1, 2007 Hello I'm birthing particles in my HDK pop, I want them to get the same attribute values as a source particle they come from. Is there a simple way to do this w/out looping over all the attrs myself. Looks like there are provisions in the birthParticle function to do it, I'm just not clear how to get the right data to put in there Here's the func I'm using from the POP_Node class: GEO_ParticleVertex * birthParticle (POP_ContextData *data, GEO_PrimParticle *part, const UT_Vector4 &pos, POP_AttribMap *map, GB_AttributeData *inherit, GB_AttributeData *split, POP_IntFunc originIndex, int originGeo, int originUse, POP_FloatFunc lifetime, POP_BirthAttribFunc birthAttrib=NULL, void *userData=NULL) Right now I'm simply putting NULL in those slots, particles are birthed but of course I don't get the attr inheritance. So in the case below "centerPt" is a GEO_Point (that came from an existing particle).. I want the new particle to essentially be a copy of that one. pvtx = birthParticle(data, part, centerPt->getPos(), NULL, NULL, NULL, (POP_IntFunc) 0, 0, POP_ORIGIN_INDEX, (POP_FloatFunc) &POP_SoftBody::getLifetime); Thanks for any help D Quote Link to comment Share on other sites More sharing options...
Infernalspawn Posted October 2, 2007 Share Posted October 2, 2007 Hi Daniel, i guess you can do this in the same function where you now put your NULL in, your feeding the centerPt->getPos() into the position i guess, and in the same way you cam provide some kind of mapping with the POP_AttribMap and use the GB_AttributeData inherit the data from the old particles. At such i point i wish a better documentation for the HDK, but thats what i found in the H8 HDK documentation 00510 // birthParticle() should be used to birth particles into a particle 00511 // system 00512 // data POP_ContextData being used 00513 // part particle primitive to birth into 00514 // pos position of the birthed point 00515 // map mapping for inheriting attributes from the inherit 00516 // GB_AttributeData 00517 // inherit inherit general attributes (required when map is used) 00518 // split inherit parental attributes (parent, origin, 00519 // generation) 00520 // originIndex origin index value. 00521 // originGeo origin from geometry number 00522 // originUse how to set origin id. Bit mask 00523 // POP_ORIGIN_INDEX: add passed in index 00524 // POP_ORIGIN_GEO: add source geometry number 00525 // POP_ORIGIN_PARENT: add split origin 00526 // lifetime total expected life of the particle 00527 // birthAttrib function to set attributes after particle is birthed 00528 // userdata passed into birthAttrib i dont know if that helps you somehow, Infernal Quote Link to comment Share on other sites More sharing options...
Daniel Posted October 3, 2007 Author Share Posted October 3, 2007 Hi Daniel, i guess you can do this in the same function where you now put your NULL in, your feeding the centerPt->getPos() into the position i guess, and in the same way you cam provide some kind of mapping with the POP_AttribMap and use the GB_AttributeData inherit the data from the old particles. At such i point i wish a better documentation for the HDK, but thats what i found in the H8 HDK documentation 00510 // birthParticle() should be used to birth particles into a particle 00511 // system 00512 // data POP_ContextData being used 00513 // part particle primitive to birth into 00514 // pos position of the birthed point 00515 // map mapping for inheriting attributes from the inherit 00516 // GB_AttributeData 00517 // inherit inherit general attributes (required when map is used) 00518 // split inherit parental attributes (parent, origin, 00519 // generation) 00520 // originIndex origin index value. 00521 // originGeo origin from geometry number 00522 // originUse how to set origin id. Bit mask 00523 // POP_ORIGIN_INDEX: add passed in index 00524 // POP_ORIGIN_GEO: add source geometry number 00525 // POP_ORIGIN_PARENT: add split origin 00526 // lifetime total expected life of the particle 00527 // birthAttrib function to set attributes after particle is birthed 00528 // userdata passed into birthAttrib i dont know if that helps you somehow, Infernal Right, looks like there are the provisions to pass on the attr data, I just can't figure out how to build those objects to pass in. The mapping of attrs should be the same (I'd think) since the src and dst parts are in the same detail so they'd have the same attrs and attr order etc. I'm wondering if the mapping is optional and I can just pass the attribs across. Anyway, I have a mail into support to see how to get that to work. Thanks Mr. InfernalSpawn Daniel (I need a cooler name.. damn) Quote Link to comment Share on other sites More sharing options...
