3__ Posted October 8, 2007 Share Posted October 8, 2007 Is there a way to make attribcreate leave an attrib its writing, if the point no-longer belongs to the group its writing to? At the moment its resetting the attribute to its default value, which seems wrong given the point is no longer in the group and should be totally excluded from the effection of the sop... I'm attempting to write sticky data, once a condition is met, in this case $TY of this frame is less than $TY of the previous. -cpb Quote Link to comment Share on other sites More sharing options...
edward Posted October 8, 2007 Share Posted October 8, 2007 When you have attribute data, every element must have a value. If you want to exclude a point from being computed, just use the group in your downstream SOPs. Quote Link to comment Share on other sites More sharing options...
3__ Posted October 9, 2007 Author Share Posted October 9, 2007 attached is a crude hack. it only works once tho. stickyAttribs.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
