dschnee Posted July 12, 2002 Share Posted July 12, 2002 I'm looking for advice for any of you that are using this card, and how to Optimize it for Houdini use . . . I'm running 5.0.46 and I seem to have some OpenGL issues in the viewport using just about every display option . . . Poly's look to be facing inward . . . and under any Hidden Line and Wireframe display's I get not much at all . . . unless I zoom in tight and then it shows up like a clipping plane depending on my level of zoom. The driver version is 29.80 for the ti4600. Thanks, -d Quote Link to comment Share on other sites More sharing options...
mike Posted July 14, 2002 Share Posted July 14, 2002 hi, I am using the detonator version 29.42 on win 2k, works fine without problems. There also exists a new version 30.30 at guru3D ,maybe this will work also !? cheers michael Quote Link to comment Share on other sites More sharing options...
dschnee Posted July 25, 2002 Author Share Posted July 25, 2002 ; ...I've tried all the current driver versions, and the OpenGL issues still stands... Not sure where to move from here... I know a few of you use the Gainward card, if anyone can shed some light, I'll open my sun roof. Current Specs... Gainward GeForce4 750/XP Gold w/ v29.42 invidia drivers Win2000 SP2 P4/1.7ghz SuperMicro P4SBA 1GB ram Houdini 5.046 build... Thanks in advance, -d Quote Link to comment Share on other sites More sharing options...
mike Posted July 26, 2002 Share Posted July 26, 2002 Hi, I'm running the same configuration and it works fine. The only differents is cpu: athlon not P4. Have you turned off the "smooth wire" option ? That's the only problem I found, if it's turned on the performance goes down very fast . (and I dont't know if it is importend, we running 5.5.33 beta ). michael Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted July 26, 2002 Share Posted July 26, 2002 isn't "smooth wire" same as wireframe antialiasing? I actually prefer to turn mine off most of the time just to have the extra processing power for dealing with higher res geometry. I am running on Oxygen GVX1 with the last, 1+ years old driver that 3Dlabs seem to have abandoned... Quote Link to comment Share on other sites More sharing options...
dschnee Posted July 26, 2002 Author Share Posted July 26, 2002 I'm starting to think it's the current version and build... I do have smooth lines turned off, yet once I have a few other apps going, ie explorer browser, and some multi-tasking, it usually will slow houdini to stand still. Even moving the mouse over buttons on the UI, you can see it take the time to draw it out... very slow and frustrating... I also have the GVX1 Pro, that sucker is stable, but its technology is sluggish, I wanted to use the Gainward card until I can swindle myself into getting one of the Wildcat VP cards based on the new P10 graphics chip... OpenGL 2.0... does 5.5+ support OpenGL2.0? -d Quote Link to comment Share on other sites More sharing options...
