Div Posted October 23, 2007 Share Posted October 23, 2007 (edited) Hi, I find Andrew Schneider's VEX flame shader ( http://www.cgijedi.com/scripting/maya&...ni_shaders.html ) but it's a text file, and i don't find any way to import it ... How can I import/use it ? If someone can help me.... Thanks Edited October 23, 2007 by Div Quote Link to comment Share on other sites More sharing options...
crunch Posted October 23, 2007 Share Posted October 23, 2007 Hi,I find Andrew Schneider's VEX flame shader ( http://www.cgijedi.com/scripting/maya&...ni_shaders.html ) but it's a text file, and i don't find any way to import it ... How can I import/use it ? If someone can help me.... Thanks From the command line tools, run vcc -l otlname shadername.vfl and it will create an otl that you can import into Houdini. Quote Link to comment Share on other sites More sharing options...
Div Posted October 23, 2007 Author Share Posted October 23, 2007 Ok, i compiled the otl thanks to you; i have now to find a way to import otl in houdini.... Thanks Quote Link to comment Share on other sites More sharing options...
stevenong Posted October 23, 2007 Share Posted October 23, 2007 Go to the File menu > Import Digital Asset Library..., select the shader you compiled & change "Install Library To:" option to "$HOME/houdini9.0". Cheers! steven Quote Link to comment Share on other sites More sharing options...
Div Posted October 23, 2007 Author Share Posted October 23, 2007 Thanks a lot, Quote Link to comment Share on other sites More sharing options...
