doc Posted November 1, 2007 Share Posted November 1, 2007 So I've created a couple of objects with different sopnets in each. When I go into the object I see the geometery created by the sopnet in that object node as well as all of the other objects in the scene. In houdini 8 there's the "see one/all objects" toggle in the bottom left hand corner of the viewer. Is there an equivalent in 9? where do I find it? What does the icon look like? Thanks L Quote Link to comment Share on other sites More sharing options...
Jason Posted November 1, 2007 Share Posted November 1, 2007 So I've created a couple of objects with different sopnets in each.When I go into the object I see the geometery created by the sopnet in that object node as well as all of the other objects in the scene. In houdini 8 there's the "see one/all objects" toggle in the bottom left hand corner of the viewer. Is there an equivalent in 9? where do I find it? What does the icon look like? Thanks L You'll find it in here (as Show all/ ShowGhosted.. /etc) http://localhost:48626/basics/view PS. it appears at the top right of the viewport. Quote Link to comment Share on other sites More sharing options...
