If() Statement Complications
Tamis
so i'm writing a vex sop operator.
i got 2 variables
int primm;
vector pos;
i derived these variable of the import(); command, so both variables ar basicly aray's.
now i wrote a if statement:
if(primm==1)
P=pos;
else
P=P;
now the problem is is that the if command only looks at the first point he gets and based on that he desides.
rather or not to do 0 ore 1.
is there a possebilaty to check on a per point basis ?
  • 1 month later...
not sure what the problem could be... you should really post the file. But for an `if` to iterate it needs to be inside some kind of `for` or `while` block. But again no idea how exactly you are trying to use your if. Or you can pipe in the point number as an iterator in vex as well.
