ivan Posted November 15, 2007 Share Posted November 15, 2007 anybody figure out how to use 'em? The HDK headers have tons of new stuff in 'em, so I know it's still active. I got my old VRAY_Procedural to compile now, and I've installed it just like in H8.1, but the object doesn't have "mantra procedurals" as a regular option. It seems to be available in "obsolete houdini 8" which doesn't sound very promising.... Quote Link to comment Share on other sites More sharing options...
crunch Posted November 16, 2007 Share Posted November 16, 2007 ivan said: anybody figure out how to use 'em? The HDK headers have tons of new stuff in 'em, so I know it's still active. I got my old VRAY_Procedural to compile now, and I've installed it just like in H8.1, but the object doesn't have "mantra procedurals" as a regular option. It seems to be available in "obsolete houdini 8" which doesn't sound very promising.... There are geometry SHOPs. So you probably need to make a SHOP. This allows you to do things like point instance your procedural if it makes sense (things like delayed read archives do make sense). Quote Link to comment Share on other sites More sharing options...
ivan Posted November 16, 2007 Author Share Posted November 16, 2007 (edited) I kinda tried this. I put down a "mantra program procedural" shop and put demobox in the program field. Then I attatched it to my object under the geometry tab, where it says "Procedural Shader" no dice. squat nada. din't work. it spit this at me: sh: line 0: exec: demobox: not found mantra: program[/obj/geo1] unable to load geometry I tried different spellings/capitolizations.... it seems to be going in to the IFD: ray_start object # { ray_transform 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1 ray_procedural -m -0.5 -0.5 -0.5 -M 0.5 0.5 0.5 program demobox ray_geometry /obj/geo1/point1 ray_property object name "/obj/geo1" ray_end # } and if I do a mantra -V5, I can see the procedural is getting registered: Registering procedural 'demobox' crunch said: There are geometry SHOPs. So you probably need to make a SHOP.This allows you to do things like point instance your procedural if it makes sense (things like delayed read archives do make sense). Edited November 16, 2007 by ivan Quote Link to comment Share on other sites More sharing options...
crunch Posted November 16, 2007 Share Posted November 16, 2007 ivan said: I kinda tried this. I put down a "mantra program procedural" shop and put demobox in the program field.Then I attatched it to my object under the geometry tab, where it says "Procedural Shader" no dice. squat nada. din't work. it spit this at me: sh: line 0: exec: demobox: not found mantra: program[/obj/geo1] unable to load geometry I tried different spellings/capitolizations.... it seems to be going in to the IFD: ray_start object # { ray_transform 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1 ray_procedural -m -0.5 -0.5 -0.5 -M 0.5 0.5 0.5 program demobox ray_geometry /obj/geo1/point1 ray_property object name "/obj/geo1" ray_end # } and if I do a mantra -V5, I can see the procedural is getting registered: Registering procedural 'demobox' Close... You've chosen the "program" procedural, not the "demobox" procedural. The program procedural is a different procedural which runs an external application and reads geometry from stdin (thus the failure to be able to run the "demobox" application). You need to create a new SHOP for your procedural. As a quick way to check, you can use the "generic geometry" SHOP and fill in the command line you want... Quote Link to comment Share on other sites More sharing options...
ivan Posted November 16, 2007 Author Share Posted November 16, 2007 ok... makes sense... now how would I write a geometry SHOP? should be mostly just a UI... do I just make a .ds script and put it somewhere? according to the help, there is no geometry context, just displace,fog,light,photon,shadow,surface,chop,cop,image3d,pop,and sop. no examples. The "code" page on the Type Properties states "this operator is not implemented in code"... crunch said: Close...You've chosen the "program" procedural, not the "demobox" procedural. The program procedural is a different procedural which runs an external application and reads geometry from stdin (thus the failure to be able to run the "demobox" application). You need to create a new SHOP for your procedural. As a quick way to check, you can use the "generic geometry" SHOP and fill in the command line you want... Quote Link to comment Share on other sites More sharing options...
crunch Posted November 16, 2007 Share Posted November 16, 2007 ivan said: ok... makes sense... now how would I write a geometry SHOP? should be mostly just a UI... do I just make a .ds script and put it somewhere? according to the help, there is no geometry context, just displace,fog,light,photon,shadow,surface,chop,cop,image3d,pop,and sop. no examples. The "code" page on the Type Properties states "this operator is not implemented in code"... Good question. In fact, it is possible to create a .ds file and put it somewhere... But I'd have to dig around for the files and it's quite problematic. The easier way is to go to the Operator Type Manager (Windows Menu) In the "filter" type "program" so that you can find the program procedural shader quickly. Once you've found Shop/vm_geo_program, use the RMB over the entry and choose "Copy..." This allows you to create a new procedural shader. You can edit the parameters to your heart's content. Quote Link to comment Share on other sites More sharing options...
ivan Posted November 16, 2007 Author Share Posted November 16, 2007 (edited) hokay, I have a new procedural, but it inherits what it puts into the IFD from the copied SHOP, i.e I make a "demobox" SHOP by copying a metapoly SHOP and renaming it, etc... then attatch the demobox to an object, and the IFD file will put this in: ray_start object # { ray_transform 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1 ray_procedural metapoly ray_geometry /obj/geo1/point1 ray_property object name "/obj/geo1" ray_end # } even though my new shop doesn't have "metapoly" in it anywheres.... how do I control what the SHOP puts in to the IFD? crunch said: Good question.In fact, it is possible to create a .ds file and put it somewhere... But I'd have to dig around for the files and it's quite problematic. The easier way is to go to the Operator Type Manager (Windows Menu) In the "filter" type "program" so that you can find the program procedural shader quickly. Once you've found Shop/vm_geo_program, use the RMB over the entry and choose "Copy..." This allows you to create a new procedural shader. You can edit the parameters to your heart's content. Edited November 16, 2007 by ivan Quote Link to comment Share on other sites More sharing options...
crunch Posted November 16, 2007 Share Posted November 16, 2007 ivan said: hokay, I have a new procedural, but it inherits what it puts into the IFD from the copied SHOP, i.eI make a "demobox" SHOP by copying a metapoly SHOP and renaming it, etc... then attatch the demobox to an object, and the IFD file will put this in: ray_start object # { ray_transform 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1 ray_procedural metapoly ray_geometry /obj/geo1/point1 ray_property object name "/obj/geo1" ray_end # } even though my new shop doesn't have "metapoly" in it anywheres.... how do I control what the SHOP puts in to the IFD? Check the "Shader name" in the type properties... Quote Link to comment Share on other sites More sharing options...
ivan Posted November 16, 2007 Author Share Posted November 16, 2007 right! got it! I totally owe you a nice glass of quality bourbon.... crunch said: Check the "Shader name" in the type properties... Quote Link to comment Share on other sites More sharing options...
