wixman Posted November 21, 2007 Share Posted November 21, 2007 I'm trying to achieve maya style goaling with the creep node - from what I can see though the creep node is either on or off and you can't adjust the strength - I'd like to use the creep node to drive particles using surface UV but also have some influence from dynamic forces. I've done some searching and apparently there used to be some tutorial on cmivfx describing this but I don't think it exists anymore... anyone got any suggestions? Thanks! Quote Link to comment Share on other sites More sharing options...
SpencerL Posted November 21, 2007 Share Posted November 21, 2007 Check out the Property POP. This allows you to set Friction, Cling, etc on a per particle basis. Also you can use the state POP to set which particles you want stuck, sliding, etc. Quote Link to comment Share on other sites More sharing options...
