Water Like Fluid
darkchild
hi,
can anyone tell me hoe to make the particle fluid less viscous?the viscosity is set to 0 anyway..and playing with the particle separation gives weird results..i need a more flowy water like fluid.
Hey there,
Personally I've found the only way is to use more particles (by using a smaller separation). You can also try use the Gas Pressure instead of Liquid Pressure, but that really gives very different results. What do you mean weird results? Can you post any movies?
Hey there,
weird results as in not water like..its too thick and changing it to gas pressure and reducing the particle separation doesnt really do anything either. These are just tests im doing with particle fluid emitters. i need my fluid to flow more easily
Is this seeming too thick in the internal motion? Or does it seem too thick when running over other objects? What I'm wondering is if there is perhaps such Friction that could make it seem to be more slippery when colliding with boundaries.
i think its the internal motion although when colliding with objects, it doesnt flow as easily as water. reducing friction even a tiny bit just makes it go all over the place because of the initial splash
