illob32 Posted December 4, 2007 Share Posted December 4, 2007 (edited) Hi everybody, What are the steps to follow after I've tracked my camera in Syntheyes? I'm using Houdini 9. Thanks! Edited December 4, 2007 by illob32 Quote Link to comment Share on other sites More sharing options...
digitallysane Posted December 4, 2007 Share Posted December 4, 2007 In SynthEyes, File>Export>Houdini Script. Open the exported file (with the suffix .cmd) in a text editor, copy the text to the clipboard. In Houdini, open a textport and paste the text. You'll need to tweak a little the Composite network because the paths to the footage will be slightly incorrect. Also be aware of possible discrepancies of start frame (0 in SynthEyes, 1 in Houdini). You might need to shift the channels one frame. Dragos Quote Link to comment Share on other sites More sharing options...
illob32 Posted December 4, 2007 Author Share Posted December 4, 2007 Thanks a lot Dragos!!! I appreciate it a lot!!! Is this workflow the same with softwares like Pftrack and Boujou? Quote Link to comment Share on other sites More sharing options...
digitallysane Posted December 4, 2007 Share Posted December 4, 2007 Is this workflow the same with softwares like Pftrack and Boujou? It's a lot of time since I tested PFtrack and I can't remember. But I do remember it exports to Houdini. As for Boujou, I have absolutely no experience with it. Dragos Quote Link to comment Share on other sites More sharing options...
symek Posted December 4, 2007 Share Posted December 4, 2007 Boujou exports a whole Houdini scene (*.hip) - not a *.cmd script - but I think this is a worse solution. It's more difficult to manage multiply solves this way. Anyway I prefer scripts . Your script from a Syntheyes you can also source from a disk (without pasting). Just put in in your $HIP directory (the directory of your scene file) and write in textport: source myfile.cmd (on windows it works even without "source"). cheers, sy. PS I didn't know the trick with pasting the script, digitallysane Quote Link to comment Share on other sites More sharing options...
digitallysane Posted December 4, 2007 Share Posted December 4, 2007 PS I didn't know the trick with pasting the script, digitallysane I just found it simpler than sourcing from disk. It occurred to me while I had a SynthEyes exported script open to try to change something inside. Houdini was also open and then I thought: Why do I bother sourcing this? Dragos Quote Link to comment Share on other sites More sharing options...
