Renderfarm - Houdini Bug #29151
David Hale
This was previously posted on the SideFX Forums, here:
http://www.sidefx.com/index.php?option=com...a5612b4a81ed472
I work in the systems office where we have Houdini 9 deployed to a large renderfarm; after upgrading all of our nodes to Houdini 9, it fails to render.
We are running Houdini 9.0.782 on linux (Ubuntu 7.04).
When running the following command:
hrender -e -f 1 1 -i 1 -d mantra1 h9tester.hip
The following error is returned:
Unknown command: ndif
However when running the command:
hrender -d mantra1 h9tester.hip
It renders fine, but this is useless to us since we require a frame range specification for our nodes.
After digging into what was going on, the error seems to actually be outputting from hbatch-bin. While it's unlikely there's a quick fix for this (as it may actually be a problem coded into the binaries), I was mostly curious if anyone else has run into this problem, and if there is a solution available. Thanks.
