Off-setting A Small Animation
ragupasta
Hi guys,
As the title says I need to off-set a small animation, heres the scene...
I have used a curve for a backbone, a cricle for the cross section, and swept them into a tube and polycaped the ends. Before the sweep I have used a carveSOP, so I can control the height for animation purposes.
Inside the carveSOP I have a small expression controlling the height growth...
smooth($F/15, 0.001, 5)
Now thats all good. I have layed a line down and used a copySOP to copy those tube to the points of the line, which is fine, but I want to offset the growth, e.g: As the first tube gets to half its height, I want the next tube to start growing, and so on and so forth. Any idea's, or an I missing something obvious?
I tried using copy stamping, but couldnt get a right looking effect, although Im fairly sure thats the right way to go about it.
BaseGrowTest.hipncFetching info...
Edited by ragupasta
