Problem With Volume Rendering
hi everyone,
I have a small problem. I have been trying to render volume in Mantra, but the result is all screwed up.
I followed the old tut from Houdini 8 and generated the i3d file. Then , I had read somewhere that the ISO SURFACE SOP has a volume option in it. So I tried that and I got the result in the viewport. But , I am not sure how to render it. I tried to switch on the "RENDER METABALLS AS VOLUME " option in the render menu, but I am still not getting the result. What exactly am I missing.
Also as a request to all the HOUDINI GODS out there, could some one please write a tutorial on volume and fluid rendering. I cant seem to figure it out at all.
I am attaching the houdini file and a rendering, so you can point out where I am going wrong.
with regards
Rohan dalvi
P.S. You will need to render the cloud.i3d file
volume.hipnc
