Debug Your Scene?
n_vfx
I might come to this topic from a programmers view but to me it makes sense to debug your scenes and printing variables on the fly (or step through) to textport. How would I do that?
I've been trying to "capture" $SPEED from particles, so that I can see what ranges they're in. Maybe I'm thinking like a programmer here but a "trace" or echo within an expression, is that possible?
hey there
have u seen the details page? its one of the options u can use too have a spreadsheet of what ur attributes are.
right click on ur scene view and a list of windows will appear, the details view is the one you're after.
alternatively u can press alt + 8, to see the same window.
theres also the option of visualising attributes on points, under the display options - guides & markers-> Custom
u can add any attribute you wish to see.
ie try creating an Attribute Text, a new little option appears, u can then edit that and specify which variable you wish to lookup.
it defaults to N, so test it by adding a normal onto your geometry and you'l be saturated with numbers on the object :)
works well with particles.
hope this helps
:blink:
Thank you!
I was obviously thinking more like it would be a problem getting these numbers out. I'm slowly learning not to "teach" houdini what to show me, it's already there. :)
Hehe.. saturated yes, thanks for the "heads up".
