Particle On Path
junaid
i am trying to make stream of particle to move along on path. i had tried
here with attract particle on curve but couldn't get the right control .
here are the following control i am looking for:
1. right now particles are tumbling a lot and revolving, i should be able to minimize that.
2. particle inter-collision (so they shouldn't intersect).
3. ability to control the randomness of rotation.
4. ability to control the thickness of particle stream.
basically the idea is to move particle blocks on path with simple randomness in rotation and scale.
any sought of help will be helpful, Thanks
Junaid :)
particle_with_attract_copy.hip
  • 3 weeks later...
Junaid :)
David Gary (cmiVFX) made a tutorial on controlling particles moving along an l-system, its similar to what your looking for!
Hope that helps!
Hope that helps!
Hi Ahmad,
I have got some methods from which i am getting quite good control over it and i had made a Digital Asset for this as well... but i will definitely peep into those
videos and will check out if i can do it in a better way, Thanks many.
Junaid
