Simple Copy Of Objects
andrewlowell
Ok, so I just want to replicate the CTRL+C CTRL+V thing .. is there a way to do this without creating a big array of parameters, creating the object, and then looping through and setting all the parameters? I'm not seeing anything like a simple copy operation. (hou Python)
ok, got it ... copyNodesTo ... but what about a single object? Does if have to be defined as a tuple like
mytuple = (hou.node('obj/myteapot'),)
does anyone know how to get this to run from a function in a DA though, when I run it from the python shell it copies fine, when I run it from a function / callback on a button from a DA it gives me this ...
ah ha, I got it ... thanks Edward!
I guess when running from the shell you don't need to use the / when referencing /obj ... is that because the shell assumes that's where you're relative to?
but with a DA you need to use the '/obj'
If it runs fine in the python shell but not from a DA, then you probably don't have the right cwd/pwd.
