Hom...few Questions
AndrewVK
Is it possible to provide file choice dialog with the default filename???
I am trying this, but it have no effect
camName = cam.name()
defname = camName + '.jsx'
dirpath = hou.expandString('$HIP')
fname = hou.ui.selectFile( start_directory = dirpath,
	file_type = hou.fileType.Any,
	default_value = defname,
	collapse_sequences = False,
	multiple_select = False,
	image_chooser   = False)
Is it possible to prevent user from selecting objects other than camera
not only in "Scene View" but also in Net or Tree view
I am trying this
cam = viewer.selectObjects("Select a camera and press Enter",
	use_existing_selection=False,
	quick_select=True,
	allowed_types = ["cam"])[-1]
It works in scene view, but i still can select everything in net view
problem with filename solved...
dir = hou.expandString('$HIP')
dirpath = dir + '/' + camName + '.jsx'
		pattern = '*.jsx',
if not fname.endswith('.jsx'):
	fname = fname + '.jsx'
