MPM sandy E error
cermmid
Hello,
I'm using MPM solver. I'm using cutom noise ramp to mulitply E attribute. When mpm source is set to chunky it works. When I switch it to sandy, wich also have E attribute, when I run the sim I get errot that says NAN particle velocities were detected during integration! When I turn off noise ramp on E, everything works fine. I don't get it why multiplying E causes this. Any body knows a work around or had the same issue?
