Twisted Skin
rdg
Hi
I want to skin these splines. Or I guess that skinning is the way to connect them.
But as you see on the picture the skin is twisted.
I tried to resort the points but it didn't help - it doesn't do anything.
There is probably a smart solution for this - which I cannot see and/or find.
skin_quest.hip
Thanks.
Georg
You need to sort the vertices not the points. Use a reverse sop and set the group to 0 then use the shift u option.
To keep things neat you can use a sort sop afterwards and sort by vertex order, but the skin sop will ignore the point order.
oh! -ah!
and if I scroll down in the help it is clearly described there as well ...
Thank you.
Georg
