Bend Foreach
MENOZ
hello.
i separated a grid into gropus, using facet, connectivity and partition sop. now i want to bend each group with a twist sop. like if they are cards :)
it is possible?
i see there is a foreach sop, but i don't know how to use it for my problem.
how can i repeat the twist sop for each group?
groups i created with partition sop are not shown in group field of my twist sop. why?
here's the file
thanks!
bend_frames.hipnc
i added a transform node in the foreach sop.
i'm trying to randomize the Y rotation of each piece of geometry.
but if i use rand(number) it return alwais the same random value, so all pieces are oriented the same way.
is there a ID for each piece to use in expression? just like $PT or $PR.
thanks
