I want to add a color value to the point movement using the Bland node.
jisun
Hi. Thanks for reading. It's a very simple problem. But the biggest problem is that I did the Houdini again in a year.
I want to change the abstract figure below to pig shape. In order of color values. Not all at once. I want to put color masks in order of sort number.
Thank you for your help today as well.
blend.hip
