sam Posted March 13, 2008 Share Posted March 13, 2008 (edited) Hi guys, I was wondering using a fluids smoke is there a way to control the rate at which the smoke dissipates over time? Like once its been emitted into the container is there a way to control how fast it dissolves or dissipates inside of the container? thanks Edited March 13, 2008 by sam Quote Link to comment Share on other sites More sharing options...
Vormav Posted March 13, 2008 Share Posted March 13, 2008 Hi guys, I was wondering using a fluids smoke is there a way to control the rate at which the smoke dissipates over time? Like once its been emitted into the container is there a way to control how fast it dissolves or dissipates inside of the container?thanks A couple easy ways to control it: Gas Diffuse and Gas Calculate. Gas Diffuse will spread your gas around the container, eventually thinning it out to nothing. Gas Calculate will allow you to apply a multiplier to the density to fade the smoke out over time. Both should be hooked up to the "sequel solvers" input of your smoke solver - won't work otherwise. You can use a multisolver to have both of them hooked up simultaneously. Gas Calculate: Set source/dest field to "density". Lower the "Post Mult" (many of the other mults will work, too) very slightly - say, 0.99. Gas Diffuse: Set the field to "density", give it a somewhat high (maybe 10) diffuse rate, so you can visualize its effect. I kind of like a combination of the two - with 'relaxation' turned on in the gas diffuse. 3 Quote Link to comment Share on other sites More sharing options...
larar ocdis Posted January 18, 2009 Share Posted January 18, 2009 Thanks for this It was usefull Quote Link to comment Share on other sites More sharing options...
