ddingddong Posted March 20, 2008 Share Posted March 20, 2008 I've 11 sequence blended primitives and I'd like to make final shape like below image using copy-loop. Any advice?? Thanks in advance~ P.S. I was using several sequence blend sop and made it's shape what I want ,hand-crafted , but I just thinking about there could be more technical approach. Quote Link to comment Share on other sites More sharing options...
edward Posted March 21, 2008 Share Posted March 21, 2008 copy stamp a switch sop? Quote Link to comment Share on other sites More sharing options...
ddingddong Posted March 21, 2008 Author Share Posted March 21, 2008 copy stamp a switch sop? hmm... I was tried that copy-stamp in blend factor. but it isn't work. or time shift could be answer.. Quote Link to comment Share on other sites More sharing options...
Guest Swann Posted June 20, 2009 Share Posted June 20, 2009 (edited) I've 11 sequence blended primitives and I'd like to make final shape like below image using copy-loop.P.S. I was using several sequence blend sop and made it's shape what I want ,hand-crafted , but I just thinking about there could be more technical approach. Hey ddingddong, Did you found solution for this ? I have a little similar problem. What I'm looking for is to copy some primitive on line and first and last prim should have different shapes (but the same amount of points) and all prims between should be blended. Edited June 20, 2009 by SWANN Quote Link to comment Share on other sites More sharing options...
