OTIS BUG???
I’m not sure if this is a bug, or if I might be misunderstanding the intended behaviour. When painting a specific region to limit the effect locally, it doesn’t seem to work as expected with Tissue properties (OTIS). In particular, when using Shrinkage — either through Tissue Core Rest Scale or Tissue Rest Scale — the painted region does not appear to restrict the effect to that area only.
Has anyone else encountered this, or is there a recommended approach for achieving region-specific shrinkage with the Tissue setup?
