instancing shaders
Bernard
Hello,
I want to make a particle system and instance 3 different shaders (shader_01,shader_02,shader_03) to the geometry , depending on the particle $ID.
How can I do this with this expression or is there another method?:
shader_0`rint(fit(rand($ID), 0, 1, 1, 3))`
thanks,
bern
Hello,
thanks,
bern
If you wana use it with sprites, i think you can create attribute and transfer it to one shader. Then in VEX you can check that attribute and assign ( via "If then Block" or something simmilar) different shader.
