arybashov Posted May 19 Share Posted May 19 Hi everyone, I’ve been testing Houdini MCP with Codex Desktop on Windows and put together a working setup for controlling a live Houdini session from an AI coding agent. The setup lets Codex connect to Houdini through MCP and hrpyc, so the agent can inspect and edit the current scene: create nodes, wire networks, set parameters, run Python in the open Houdini session, and work with Solaris/USD graphs. I also opened a pull request with a couple of fixes that were needed to make this reliable on Windows: - keep FastMCP stdio output clean by disabling the banner - run stdio without HTTP host/port arguments - start Houdini’s hrpyc listener through ThreadedServer - stop the hrpyc server via the server object instead of the missing hrpyc.stop_server API - document a tested Codex Desktop + Houdini 21.0 Windows setup Project page: https://arybashov.github.io/houdini-mcp/ Fork: https://github.com/arybashov/houdini-mcp Upstream PR: https://github.com/oculairmedia/houdini-mcp/pull/8 Telegram updates: https://t.me/cg_pipeline_lab Tested with: - Windows 11 - Houdini 21.0.671 - Codex Desktop - Python 3.14 - RPyC 5.3.1 The most stable architecture so far is: Codex Desktop -> stdio MCP server running in normal Python -> RPyC 5.x -> Houdini hrpyc listener on 127.0.0.1:18811 I’m sharing this in case other Houdini users are experimenting with AI agents, MCP, Solaris/USD automation, or DCC pipeline tools. Feedback and testing on other Houdini versions would be very useful. Quote Link to comment Share on other sites More sharing options...
