Particle color from texture?
Korhon
Did try the search engine :)
But in the example file that you found its not using the uv from the object. Its using a boundinbox to project the texture to the grid.
I have a object that is made in maya and uvmapped. How can i use the uvmap that comes with the model?
And also when using the pointsop to add color to the geometry you have to have a hires mesh to get all the fine details from the texture.?
Is there a different approach thats not using the pointsop to create color atributtes?
Maybe is just me not understanding how this setup realy works :) Still new to Houdini!
Thanks!
Ok, sorry than.
It goes almost the same way. You can replace $BBX [Y] variable in expression (PointSOP) for $MAPU [V], or add ColorPOP with similar way. I turned off Point SOP and applied color in POP. Turn in back on to see the first path.
I think there are others way also. Expressions are little slow. It could be a problem with heavy geometry. Perhaps inheriting UV by particles and applying color in VEX would be better choice...
HTH,
sy.
particle_colors_skk.hipnc
Edited by SYmek
