ubuntu linux
silentvisual
Once you have installed Houdini and the license server, all you have to do is navigate to the install directory and type
"source houdini_setup". That will take care of everything. It should then tell you the environment has been initialized.
After that all that is required is to type "houdini". Also I believe the installer also has options for installing menu items
to launch Houdini.
