How to do opacity Mapping
zasid
Hello ,
I made this tiff file (then converted in RAT format) with Alpha channel saved on it but when I do the opacity in the Alpha value of the vex layers surface it doesn't do any thing please help me. I am attaching the hip file and the rat file.
OPACITY.hipncFetching info...
OPACITY_MAPPING.zipFetching info...
Edited by zasid
Seems to work fine over here (though I used a different font because you didn't include the font file -- but that's not the problem here).
The only thing I did was set the render flag on the Material SOP (you left it on the UVEdit SOP). So it seems you were rendering with the default shader.
HTH.
HTH.
Hello Mario,
No its not working I tried the same .It only shows me the results in the Alpha Channel of Mplay.I want to see the results in my Color Chanels with the wholes in them that it should take out from the Alph Channel included with in the Aplh Channel of the tiff or rat image.
Can you send back the hip file that you worked on thanks.
  zasid said:
Hello Mario,
Hello Mario,
I have done it thanks problem was there were no lites in the scene :D Thanks for the help anyways.
