Bend Tool Using Lattice
davidwick
Hello odforce. I've enjoyed browsing the forum over recent weeks and the time has come to speak!
I'm working a bend tool which behaves differently to the Twist SOP. This tool uses a Lattice SOP to e.g. bend a tube into a torus. (I'm new to Houdini, so perhaps a similar tool already exists.)
The attached version uses a Point SOP to deform the control geometry. I'm also fine-tuning a version using 30 Transform SOPs to achieve the same effect. This works smoothly whereas the Point SOP version is relatively slow, with stepped pausing as it cooks.
I prefer the Point SOP version as it's a more elegant approach. Is there any way to increase its speed?
Anyway, I'll post the Transform SOP version when it's ready.
Bend_w_lattice__Point_SOP_.zipFetching info...
