Zamous Posted April 4, 2008 Share Posted April 4, 2008 (edited) I have imported a 3ds max into houdini. The model is a car I purchased from exchange3d and trying to get it shaded, textured and rendered in Houdini. Right now I have the file object. In this geometry is a large flat square above the car, is this a typical 3d thing? Is there a way to separate the geometry into separate objects? Right now it is one large object with a huge poly count. I am trying to get the object to match the top/front/side views (right now it is upside down and way off center). Is there any easy/proper way to do this? Since I have a file node, does that file have to always exist on the file system or is there a way to bring it into hip file? oh one other thing. It seems as if the import kept some sort of primative group. I am able to select windows and body part, etc. But how can I apply a material shop to just the selection? I tried to select then add group node. Thanks for any help in advance. I trying to figure this out as best as I can, but not sure what is best practice for imports. Thanks!!! mustang.hipnc Edited April 4, 2008 by Zamous Quote Link to comment Share on other sites More sharing options...
Zamous Posted April 4, 2008 Author Share Posted April 4, 2008 Turns out that I think my obj file was corrupted or something. I could select individual primatives for sops. I imported it as dxf and all my headaches disappeared. Now I am able to supply materials to primative selections. I have imported a 3ds max into houdini.The model is a car I purchased from exchange3d and trying to get it shaded, textured and rendered in Houdini. Right now I have the file object. In this geometry is a large flat square above the car, is this a typical 3d thing? Is there a way to separate the geometry into separate objects? Right now it is one large object with a huge poly count. I am trying to get the object to match the top/front/side views (right now it is upside down and way off center). Is there any easy/proper way to do this? Since I have a file node, does that file have to always exist on the file system or is there a way to bring it into hip file? oh one other thing. It seems as if the import kept some sort of primative group. I am able to select windows and body part, etc. But how can I apply a material shop to just the selection? I tried to select then add group node. Thanks for any help in advance. I trying to figure this out as best as I can, but not sure what is best practice for imports. Thanks!!! Quote Link to comment Share on other sites More sharing options...
