kensonuken Posted April 10, 2008 Share Posted April 10, 2008 I have this code and I want to add refraction map attributes to it... can anybody help me? >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /* * TLFresnelPlastic.sl -- simple shader illustrating fresnel(). * * DESCRIPTION: * Simple Fresnel shader using plastic illuminance. * * PARAMETERS * * AUTHOR: Tal Lancaster tal AT renderman DOT org * * HISTORY: * Jan 26 2002 Created */ /* From Advanced RenderMan */ #include <reflections.h> #ifdef PRMAN /* as of prman10 */ #define CHKTX(tx) ((tx != "" && textureinfo (tx, "exists", 0) != 0)? 1: 0) #else #define CHKTX(tx) \ ((tx != "")? 1: 0) #endif surface TLFresnelPlastic ( color Csurf = 0.5; /* cat Color desc {Base color for surface if not over-written by "colorMap } */ string colorMap = ""; /* cat Color desc {Optional color map. Replaces 'Csurf'.} */ float ior = 0; /* desc { Index of Refraction. Used to get Fresnel falloff. 0: turns off fresnel and gives plastic look. Typical values gt 1.0 and lt 2.2} range {1.01 2.2 .01} */ float Ka= 1; /* desc { Usual } */ float Kd= 0.5; /* desc { Usual } */ float Ks= 0.5; /* desc { Usual } */ float roughness= 0.1; /* desc {Specular roughness} */ color Cspec = 1; /* desc {Specular color} */ float Kr = 0; /* cat Reflection desc {Strength of reflection } */ string reflectMap = ""; /* cat Reflection desc {Name of reflection map. } type texture */ float reflectBlur = 0; /* cat Reflection desc {Percentage amount to blur map} */ string reflectSpace = "world"; /* cat Reflection desc {Space the reflection calculations are performed in. } */ float reflectDist = 1e10; /* cat Reflection desc {The size of the room to base the reflection lookup off of.} */ float flipS = 0; /* cat ST type switch desc {Flip S on texture lookups.} */ float flipT = 0; /* cat ST type switch desc {Flip S on texture lookups.} */ float MtorFlip = 0; /* cat ST type switch def 1 desc {Swap S/T access to overcome Maya/MtoR NURBs differences.} */ ) { float ss, tt; float fKt, fKr; color Ct; normal Nf = normalize (faceforward( normalize(N), I )); vector V = -normalize(I); vector R = normalize (reflect (I, Nf)); /* Parametric space adjustments */ if (MtorFlip == 1) { ss = t; tt = s; } else { ss = s; tt = t; } if (flipS == 1) ss = 1 - ss; if (flipT == 1) tt = 1 - tt; /* Calculate fresnel index of refraction */ if (ior != 0) { fresnel (normalize (I), Nf, (I.Nf > 0)? ior: 1/ior, fKr, fKt); /* hack */ fKt = 1 - fKr; } else { /* fresnel turned off */ fKr = fKt = 1; } /* base color */ /*Ct = (CHKTX (colorMap))? texture (colorMap, ss, tt): Csurf; */ if (CHKTX (colorMap) == 1) Ct = texture (colorMap, ss, tt); else Ct = Csurf; /* Environment */ color Cr = 0; float reflOpacity = 1; if (reflectMap != "") Cr = Environment (reflectMap, reflectSpace, reflectDist, P, R, reflectBlur, reflOpacity); /* lighting */ Oi = Os; Ci = Os * ( fKt * Ct * (Ka*ambient() + Kd*diffuse(Nf)) + fKr * Cspec * Ks * specular(Nf,V,roughness) + Kr * Cr * fKr); } >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /************************************************************************ * reflections.h - Functions which compute reflected light by either * ray tracing or environment mapping. * * Author: Larry Gritz (lg AT larrygritz DOT com) * * Reference: * _Advanced RenderMan: Creating CGI for Motion Picture_, * by Anthony A. Apodaca and Larry Gritz, Morgan Kaufmann, 1999. * * $Revision: 1.2 $ $Date: 2003/12/24 06:18:06 $ ************************************************************************/ #ifndef REFLECTIONS_H #define REFLECTIONS_H #include "filterwidth.h" #include "raysphere.h" /* ReflMap() - Use a reflection map for reflections in flat objects. * Inputs are: * reflname - filename of reflection map * P - origin of traced ray * blur - amount of additional blur to add to environment map * Outputs are: * return value - the color of incoming light * alpha - opacity of reflection map lookup in the direction R. * Warning - the texture call itself takes derivatives, causing * trouble if called inside a loop or varying conditional! Be cautious. */ color ReflMap ( string reflname; point P; float blur; output float alpha; ) { /* Transform to the space of the environment map */ point Pndc = transform ("NDC", P); float x = xcomp(Pndc), y = 1-ycomp(Pndc); alpha = float texture (reflname[3], x, y, "blur", blur, "fill", 1); return color texture (reflname, x, y, "blur", blur); } /* Environment() - A replacement for ordinary environment() lookups, this * function ray traces against an environment sphere of known, finite * radius. Inputs are: * envname - filename of environment map * envspace - name of space environment map was made in * envrad - approximate supposed radius of environment sphere * P, R - position and direction of traced ray * blur - amount of additional blur to add to environment map * Outputs are: * return value - the color of incoming environment light * alpha - opacity of environment map lookup in the direction R. * Warning - the environment call itself takes derivatives, causing * trouble if called inside a loop or varying conditional! Be cautious. */ color Environment ( string envname, envspace; uniform float envrad; point P; vector R; float blur; output float alpha;) { /* Transform to the space of the environment map */ point Psp = transform (envspace, P); vector Rsp = normalize (vtransform (envspace, R)); uniform float r2 = envrad * envrad; /* Clamp the position to be *inside* the environment sphere */ if ((vector Psp).(vector Psp) > r2) Psp = point (envrad * normalize (vector Psp)); float t0, t1; if (raysphere (Psp, Rsp, envrad, 1.0e-4, t0, t1) > 0) Rsp = vector (Psp + t0 * Rsp); alpha = float environment (envname[3], Rsp, "blur", blur, "fill", 1); return color environment (envname, Rsp, "blur", blur); } /* RayTrace() - A fancy ray trace routine, particularly suitable for * use with the "ray server." Tries to sample over the surface * element and over the varying ray spread due to surface curvature. * An ordinary call to trace would point sample the environment in a * very simplistic way. This function takes the size of the surface * facet and curvature of the surface into account, and lets you * sample the space with multiple rays. * * Inputs: * P - surface position * Rdir - the unit-length reflection direction. * blur - reflection blurriness; 0 = sharp reflection * jitter - when 1, fully jitter the stochastic ray directions. Lower * numbers jitter less, 0 doesn't jitter. Lowering jitter may help * alleviate "sparkling" due to animation with low nrays. * nsamples - number of rays with which to sample. Larger numbers will * yield better-sampled reflections, but will be more expensive. * Note that the function reduces this number for secondary rays, * assuming that the distribution from primary rays will be * sufficient! * Return value: the average of the trace calls. * * Warning!!! This function takes derivatives to find out the ray spread! * This can cause trouble if RayTrace() is called inside a loop or varying * conditional! Be cautious. */ color RayTrace (point P; vector Rdir; float Kr, blur, jitter; uniform float nsamples; output float alpha;) { #if (defined(BMRT) || defined(RAYSERVER_H)) float rand () { extern float jitter; return (raylevel()==0) ? (0.5 + jitter * (float random() - 0.5)) : 0.5; } extern float du, dv; color C, Ct; float hitdist; point Phit, Pmiss; vector Nhit, Rmiss; float bluramt = blur + filterwidthp(Rdir); uniform float nrays = (raylevel() == 0 ? max(1,ceil(sqrt(nsamples))) : 1); vector Tu = Du(P) * (1.5 * du); /* overblur just a tad... */ vector Tv = Dv(P) * (1.5 * dv); if (Kr < 0.0001) { C = 0; } else if (bluramt > 0 || nrays > 1) { /* Construct orthogonal components to Rdir */ vector uoffset = blur * normalize (vector (zcomp(Rdir) - ycomp(Rdir), xcomp(Rdir) - zcomp(Rdir), ycomp(Rdir) - xcomp(Rdir))); vector voffset = Rdir ^ uoffset; uniform float i, j; C = 0; alpha = 0; for (i = 0; i < nrays; i += 1) { for (j = 0; j < nrays; j += 1) { /* Add a random offset to the smooth reflection vector */ vector R = Rdir + ((i + rand())/nrays - 0.5) * uoffset + ((j + rand())/nrays - 0.5) * voffset; R = normalize®; point Pray = P + ((j + rand())/nrays - 0.5) * Tu + ((i + rand())/nrays - 0.5) * Tv; fulltrace (Pray, R, Ct, hitdist, Phit, Nhit, Pmiss, Rmiss); C += Ct; alpha += 1 - step(1.0e10,hitdist); } } uniform float totrays = nrays*nrays; C /= totrays; alpha /= totrays; } else { /* No blur or curvature, just do a simple trace */ fulltrace (P, Rdir, C, hitdist, Phit, Nhit, Pmiss, Rmiss); alpha = 1 - step(1.0e10,hitdist); } return C; #else return color 0; #endif } #define ENVPARAMS \ envname, envspace, envrad, rayjitter, raysamples #define DECLARE_ENVPARAMS \ string envname, envspace; \ uniform float envrad, rayjitter, raysamples #define DECLARE_DEFAULTED_ENVPARAMS \ string envname = "", envspace = "world"; \ uniform float envrad = 100, rayjitter = 0, raysamples = 1 color SampleEnvironment (point P; vector R; float Kr, blur; DECLARE_ENVPARAMS;) { color C = 0; float alpha; if (envname != "") { if (envspace == "NDC") C = ReflMap (envname, P, blur, alpha); else C = Environment (envname, envspace, envrad, P, R, blur, alpha); } #if (defined(BMRT) || defined(RAYSERVER_H)) color Cray = RayTrace (P, R, Kr, sqrt(blur), rayjitter, raysamples, alpha); C = Cray + (1-alpha) * C; #endif return Kr * C; } #endif /* defined(REFLECTIONS_H) */ >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> thanks, ken Quote Link to comment Share on other sites More sharing options...
