vex variables
MENOZ
hello, i'm trying to understand vex shaders.
in turbulent node vex node i have a P input parameter. what is it exactly?
should i put the P from global variables to P of turbnoise? if i do that my texture will not follow the surface of my object.
if u use S and T, with a float to vector node, i will have discontinuities on the seams.
can you help me please?
thanks!
You are so close...
P is just a point position that drives the noise.
Global P is the point position of the shaded point, BUT it comes in in camera space (or think of it as world space)
Use a transform vop to convert it to object space first then feed it to your noise vop. That should make it stick.
You are so close...
so global P is looped along all the points of the surface, and at each point it return a different value.. and the noise function takes this vaule at each point to make his operations..
and this is also true for the S and T coords, i think.
because if i use a texture vop, and i feed it with a constant vop it generate stripes, because at each point being sampled, the texture vop alwais takes the same "position", so it return alwais the same value.
it's correct?
with a transform vop it works whe i render! thenks. but there is a way to stick the texture in the shader view too? it continue to be in camera space.
thank you!
it's correct?
thank you!
correct
as for the shader view, I assume you mean the shader ball? yes from memory I think that never sticks.
