goldleaf Posted April 30, 2008 Share Posted April 30, 2008 Is there a way to rotate the pivot points of an object? I know via the insert key you move that point, but I haven't found how to rotate it. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted May 1, 2008 Share Posted May 1, 2008 Unfortunately you can't do that. What you can do though is "detach" the transform handle and rotate that. You can do that by hitting backtick on the keyboard. If you really want a rotated pivot permanently then parent your object to a rotated null using keep position when parenting and then move the null. Quote Link to comment Share on other sites More sharing options...
goldleaf Posted May 2, 2008 Author Share Posted May 2, 2008 Unfortunately you can't do that.What you can do though is "detach" the transform handle and rotate that. You can do that by hitting backtick on the keyboard. If you really want a rotated pivot permanently then parent your object to a rotated null using keep position when parenting and then move the null. Okay. Thanks sib. Quote Link to comment Share on other sites More sharing options...
