crovfx Posted May 8, 2008 Share Posted May 8, 2008 Hi everyone, firstly I would like to say that I've seen some truly wonderful work on this forum and as a transferring Maya -> Houdini artist many times I was left in awe; Houdini truly is a way of thinking. For now I had more luck drawing on my shake node based experience than on years of actively using Maya Now I am presented with a problem of creating a dusty trail; I went through the fx tools heavy smoke setup but I still do have a question because I am not clear on this: How to scale the metaballs radius based on particle's age. I have some ideas, but again, my knowledge of Houdini operators is still very limited so I'll better keep quiet . Also, what would be the recommended way of shading the metaballs once the motion is done, taking into account life opacity etc. Thank you everyone and hopefully one day I'll be in the position to return the favour Best regards. - P.S. - All Maya fluids, FumeFX & Realflow questions are welcomed (willing to send you a setup if necessary). Quote Link to comment Share on other sites More sharing options...
aracid Posted May 8, 2008 Share Posted May 8, 2008 hey crovfx welcome to odforce, glad u like the tool regarding the scaling issue, the trick here is too use the $LIFE in the pscale variable. and u can do this with the point sop. so basically, place a point sop after ur particle sim and before ur copy sop, and make sure u have the pscale parameter set too $LIFE. an alternative would be using 1-$LIFE or any function that uses $LIFE as a lookup to modify the scale. alternatively, take a look at the particle fluid surface SOP, thats great for surfacing fluids hope this helps brian Quote Link to comment Share on other sites More sharing options...
crovfx Posted May 8, 2008 Author Share Posted May 8, 2008 Hi Illusionist, thank you for your very fast reply; it worked like a charm and I am in debt. Really I mean it, anytime you have any questions in connection to any Maya stuff I will share my experience and do my best to try and return the favour Kind Regards, crovfx Quote Link to comment Share on other sites More sharing options...
Netvudu Posted May 8, 2008 Share Posted May 8, 2008 (edited) Hi Illusionist,thank you for your very fast reply; it worked like a charm and I am in debt. Really I mean it, anytime you have any questions in connection to any Maya stuff I will share my experience and do my best to try and return the favour smile.gif As an initial favour you could start by calling him aracid instead of illusionist, hahah Keeping on with what aracid was hinting and taking into account his Houdini knowledge swiftly kicks my a$$ anytime, you would do a great favour to yourself if you work into the concepts of variables and attributes as solely those concept will make half of the way for you in your Maya-Houdini transition. Most SideFx tutorials use them as it Edited May 8, 2008 by Netvudu Quote Link to comment Share on other sites More sharing options...
crovfx Posted May 8, 2008 Author Share Posted May 8, 2008 He, he...Illusionist...unbeliavable how long has it been since I've actively participated on a forum; growing old I guess - can't differentiate between ranks and usernames Thank you for the advice Netvudu; gotta swing by your tavern for an ale All best Quote Link to comment Share on other sites More sharing options...
doc Posted May 9, 2008 Share Posted May 9, 2008 regarding the scaling issue, the trick here is too use the $LIFE in the pscale variable. You might also consider using chf("../lookup"($AGE*$FPS) instead of life. I often find that during the course of a shot I have to change the life span of my particles. This will change the value of $LIFE as it will adjust to the new lifespan. If I use $AGE*$FPS you won't have this problem. chf() is an expression that looks into another channel at a specified frame to retrieve a value. It's kind of like set driven key in maya. type: exhelp chf() in a texport to get the details. usually I'll just make a spare channel called "lookup" and refer to that. Another advantage of doing it this way is that you can control the "falloff" of your pscale. hope that helps Quote Link to comment Share on other sites More sharing options...
crovfx Posted May 22, 2008 Author Share Posted May 22, 2008 Thx a lot for Doc, as you've said it's much more convenient as I don't have to change the expression if do any changes to the lifespan. Thx & all best Quote Link to comment Share on other sites More sharing options...
