Simple DOP problem How to Apply 2 gravities on Same fractured object
zasid
Hello guys,
I have a fractured object I want certain chunks to fall down at a certain time I know the ACTIVE key method as OLD SCHOOL HELPED me out with that .
but the problem now is
MY FRACTURED OBJECT is in an influence of GRAVITY FORCE IN X DIRECTION
I want my CHUNKS to fall down in Y Direction while its moving by the gravity force in X direction how can I do it ??
I played with DOP groups ACTIVE KEY but no hope can any one help me out m posting my hip file also for convenience.
Many Thanks.
zasid
DOPS_PROBLEM.zipFetching info...
Just wanna add, if you want more randomness to your objects being pulled by gravity, inside your gravity dop, it has a -9.8??? value in Y, change it to -9.8+(rand($OBJID)-0.5)*2 so that for each object, the gravity force actually is different for each of them.
