Volume Smoke example problem (solved)
you can try decreasing the " Volume Step Size " in the mantra rop right underneath the sampling. It defaults to 0.1 so you can take it down to 0.05 and see what happens. Also maybe it has something to do with the resolution and/or sampling of the depth shadow map.
cheers
Edited by ihab
