Groups not working in RBD GLUE
zasid
Hello Guys,
I declare a group on few chunks on my RBD glue object so that i can make them fall thro gravity after some time but they dont seems to work
how ever they work great on fractured object .what should i do to make them work on RBD Glue objects.
Thanks.
Zasid
Edited by zasid
Hello guys,
I have managed to do it thro RBD state but the problem now is that once they fall they dont interact with the ground floor for collision the just fall straight away and dont interact with the static geometry for collision.
Awaiting response. Many thanks.
hi zasid, i'm not sure if I understand your question right. I did a simple test of RBD Glue object and it works well. Could you post a file that people here can take a look?
edit: sorry, just saw your picture. Could you try to change the collision relationship to Mutual, or switch the sequece of the two nodes to Merge?
Edited by curveU
Here is picture for better understanding the problem.
Hello guys,
:D its sounds a bit funny but have solved it after posting the picture i looked at the network again and it was just the manipulation of the network nodes that wasn't there and I have solved it .Never mind !!!
thanks alot .
