POP's
hello there a quick question i have a POP's system and i'm trying to make a crowd simulation but i can't get the attractor POP to work.
it said in the help that i have to have a point sop on the object i'm using as the attractor but i can get it to work. i think i'm missing something.
this is in referance to my post on the character section My post
cheers bren
instead of using a point sop, try this:
Copy metaballs onto whatever points you wanted to use as attractors.
Then append a force Sop and set some values.
Source that in your attractor pop.
That should work for you. It's a bit odd though, cause you have to modify the values in sops. Oh well.
Once you've got that working, maybe try the point sop thingy again.
Cheers,
Snej
