aracid Posted May 31, 2008 Share Posted May 31, 2008 Hi all Has anyone attempted to render an SDF directly, or knows of a method to do so, that produces fairly good results ? When I try render it, my results flicker, even though I do blur the SDF. This is an attempt render of the volume/SDF using the volume sampler, I was wondering if generally studios convert the SDF to a polygon, ie isosurface sop or do they write a procedural that handles this issue? thanks in advance brian Quote Link to comment Share on other sites More sharing options...
Jason Posted June 1, 2008 Share Posted June 1, 2008 Back on The Day After Tomorrow I attempted rendering levelsets (from our fluid-sim software) directly in Mantra by converting the SDF to .i3d format and using the intersect3d() VEX function and shading the surface based on the gradient. This was done in a Fog shader. And it worked. And I was immediately struck with a host of additional problems: 1) Motion-blur. I could not figure out a way to do that (effectively). However, as Volumes in Mantra now with the velocity (vel) field you could probably do it. 2) Texture coordinates. Couldn't figure out a nice way at the time to procedurally generate texture coordinate. Having the surface as geometry really helps for this. But now you do have point-clouds and stuff to help, potentially. 3) Displacement. At the time I couldn't displace either (on top of the texture coordinate problem). Now you can displace volumes, so it might be a lot better/easier. 4) Visualization. It was really hard to fumble about in the dark, trying to figure out whats going on with only renders to provide feedback. This will still be an issue, I assume. I haven't tried since:) Quote Link to comment Share on other sites More sharing options...
aracid Posted June 2, 2008 Author Share Posted June 2, 2008 Hey Jason Thanks for getting back to me, so did that mean u overcame those problems and used that method? or did u eventually convert it to geom ? Just curious if I'm being silly trying because the above image is rendered as a surface shader, it pops a little here and there. One thing that became apparent really quickly was the difference in speed, rending the isosurface with $V as the variable and a fair resolution vs the volume with a surface shader with a condition rendering the 0, the geo was a lot faster, however I dont know how well this scales. When i write the geo out to disk, the files are really large, however the SDF isn't nearly as big. any ways, ill just continue tapping this problem, thanks again for the info. Quote Link to comment Share on other sites More sharing options...
Jason Posted June 3, 2008 Share Posted June 3, 2008 We opted for geometry, yes. It allowed us to lop off offending parts of the sim, filter it, texture it, and add detail back with displacement shading. (Much more detail than we lost by approximating the level set with geometry) Quote Link to comment Share on other sites More sharing options...
