lisux Posted October 23, 2014 Share Posted October 23, 2014 Can we use Extract Transform these days?Or go back in time and use the Align SOP, which will do exactly what Alvin needs and has been there for more than decade. Old school rules! Quote Link to comment Share on other sites More sharing options...
Tesla's fan Posted October 25, 2014 Share Posted October 25, 2014 老坟 in Chinese means "old grave". I think little math + VOP all right Quote Link to comment Share on other sites More sharing options...
nautiluz Posted October 27, 2014 Share Posted October 27, 2014 It has been a long while And today I had need of this, and decided to try again. I think I got it working! It's barebones and not tested extensively (it's waay past bedtime!), would love to hear if there is something I missed! I got the solution from: http://www.flipcode.com/documents/matrfaq.html#Q40 Q40. How do I use matrices to convert one coordinate system to another? Hi Alvin, i am a Houdini beginner and just dived into your file in order to learn from it (because this CoordinateSpaceTransformations/Virtual Parenting is something that always hooks me when it comes up). The only thing that i don´t understand really is the very first node called "non_procedural_geometry", in which you built your source geo from a triangle and use that 3 points to build your Transform Matrix later. How would i go doing the same from an arbitrary mesh, or even better, from a file-SOP with an imported already animated and baked geo? can you give me a hint? thanks in advance Quote Link to comment Share on other sites More sharing options...
Ole Posted December 5, 2014 Share Posted December 5, 2014 It has been a long while And today I had need of this, and decided to try again. I think I got it working! It's barebones and not tested extensively (it's waay past bedtime!), would love to hear if there is something I missed! I got the solution from: http://www.flipcode.com/documents/matrfaq.html#Q40 Q40. How do I use matrices to convert one coordinate system to another? Hi Alvin. I just wanted to thank you for sharing this. It has been really helpful for me lately. @nautiluz: In case you are still wondering: Setup a interface where you can set the three reference points that goes into the local space creation. Make sure they represent a flat triangle on the baked geometry. Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted January 8, 2015 Author Share Posted January 8, 2015 Whoops, sorry, didn't realize there were replies in the thread! I swear I have follow topic engaged and didn't get any emails :-/ Sadly I need this posted hip () for some stuff at work, will reply shortly! Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted January 8, 2015 Author Share Posted January 8, 2015 Whew ok this saved my butt. Anyways, using Extract Transform (this is new-er right? There was another node that required you to put in the points to track?) wasn't working for me, I always have the attached object sliding around. I'm probably doing something wrong. Also, you can concatenate multiple transforms into one matrix, which makes it highly convenient. With regards to Align, that's a cool sop! Totally missed it. Sadly, from my tests the aligned geo kept sliding around so I need to figure out where I'm using it wrongly. @nautiluz: Sorry the reply is so late. But if you replace non-procedural geo with any deforming model with a non-changing point count, it should work. @Ole: I'm glad it helped! This just saved my butt 5 minutes ago Quote Link to comment Share on other sites More sharing options...
opusscorpio Posted July 7, 2016 Share Posted July 7, 2016 On 10/23/2014 at 5:00 PM, GallenWolf said: It has been a long while And today I had need of this, and decided to try again. I think I got it working! It's barebones and not tested extensively (it's waay past bedtime!), would love to hear if there is something I missed! I got the solution from: http://www.flipcode.com/documents/matrfaq.html#Q40 Q40. How do I use matrices to convert one coordinate system to another? extractTransformMatrix_v001.hipnc Thank you very much. This helped a lot Quote Link to comment Share on other sites More sharing options...
