cspears2002 Posted June 3, 2008 Share Posted June 3, 2008 I am working out of an old Houdini tutorial. In the tutorial, I create a polygonal sphere and then copy points to the centers of the primitives that make up the sphere. This seems to work except a whole bunch of points got copied to one of the primitives for some reason. Can you help me out? I attached the scene file. centroid_particle_v03.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted June 3, 2008 Share Posted June 3, 2008 Copy SOP issue. You are making 80 duplicate copies of the points copied on the sphere. Simply remove the expression from your ncy field (number of copies) and you should be gold. GW Quote Link to comment Share on other sites More sharing options...
