Symbolic Posted June 17, 2008 Share Posted June 17, 2008 Hi, I am trying to query a node some where in my scene... ex: "/obj/curve_pack/sblend1" with a channel "seqctrl" I am trying to access the first kayframe and the last keyframe values in Frames for a specific channel. I looked through the help... I found the "chkeyls" command... chkeyls /sblend1/seqctrl and it lists: seqctrl 101 142 which are my first and last keyframes. But how can I use this in an expression? ex: automatically setting the input range and the output range of a TimeWrap node. Thanks. Quote Link to comment Share on other sites More sharing options...
rdg Posted June 17, 2008 Share Posted June 17, 2008 (edited) now tested: arg(run("chkeyls /obj/null1/parm"), 1) arg(run("chkeyls /obj/null1/parm"), 2) chkeyls is a hscript command and needs run() to output something in an expression Edited June 17, 2008 by rdg Quote Link to comment Share on other sites More sharing options...
Symbolic Posted June 17, 2008 Author Share Posted June 17, 2008 (edited) Thanks Georg! I really need to go deeper in hscript and python... Cheers. // Ok, just tried it... works perfect! Thanks! Edited June 18, 2008 by Symbolic Quote Link to comment Share on other sites More sharing options...
Symbolic Posted June 19, 2008 Author Share Posted June 19, 2008 Hi! Now I am in a new trouble. The previous command works great with actual keyframes in a channel. You know when it is green (blue) How can I access the first and the last keyframe of a channel that is overridden by a chop. ex: * I have two channels on a Null 1: sequence 2:processed_sequence * channel (1) has an animation going from 1 to 10... just normal keyframes. * I fetch this channel into chops... strech it and export it to channel (2), which is called in our case "processed_sequence" So channel (1) is blue (green) and channel (2) is orange. I can access channel (1) with: arg(run("chkeyls ./NULL/sequence"), 1) arg(run("chkeyls ./NULL/sequence"), 2) It gives me the results of 1 and 10 I am using these outputs inside a TimeWarp Node which is in the same network with my Null. But how can I get the same data for channel (2)... which is linked to a chop network... Thanks. Quote Link to comment Share on other sites More sharing options...
rdg Posted June 20, 2008 Share Posted June 20, 2008 can't you just multiply by your streching factor? I think there is something like $IC and $OC which gives you the first and last keyframes in chops. You might need to extract them into constant channels and read them from there ... Quote Link to comment Share on other sites More sharing options...
Symbolic Posted June 20, 2008 Author Share Posted June 20, 2008 Hey rdg, Thanks man... but I think this one is getting too complicated... and I am really running out of time... I think I will change my entire workflow and try to avoid the complex stuff for now... Thanks anyway. Quote Link to comment Share on other sites More sharing options...
Symbolic Posted July 6, 2008 Author Share Posted July 6, 2008 rdg said: can't you just multiply by your streching factor?I think there is something like $IC and $OC which gives you the first and last keyframes in chops. You might need to extract them into constant channels and read them from there ... The "arg(run("chkeyls ./NULL/sequence"), 1), arg(run("chkeyls ./NULL/sequence"), 2)" technique is very buggy... It just do not evaluate properly. Is there a better way of getting the frame data of the first and the last keyframes? How can I do that in CHOPs... I tried $IC and $OC in an expression CHOP but did not work... What are the exact variables? (my help is not working ) Thanks. Quote Link to comment Share on other sites More sharing options...
Symbolic Posted July 8, 2008 Author Share Posted July 8, 2008 Ok, I have done it with the following CHOPs expressions: ics(0)+1 ice(0)+1 This evaluates the first and the last key frame. Quote Link to comment Share on other sites More sharing options...
