assign color per group
MENOZ
hi!
i have an imported object sequence, with many pieces of geometry.
with the connectivity SOP and partitionSop i create the various groups for each piece of geometry.
now i want to assign a different color to each group of polygons, randomly.
how can i use the groups i created to drive the color?
if i have point i can use the $PT, but here i have sheet_0 sheet_1 sheet_2 etc..
that's the hip file for example.
sheet.hipnc
hi!
can't you use $CLASS from ConnectivitySOP as a seed for rand() for color?
I have attached connectivity and partition for making groups with $CLASS variable, but cant figure out how do i use the same for random color..?
Junaid
Append PointSOP -> Add Color, RMB -> Delete Channels, type in R: rand($CLASS) then in G: rand($CLASS+4) etc...
