squishy objects not colliding???
_suz_
haai all dextrous-ees!
here's a quick question before the wk.end:
i have a number of squishy objects in my scene, alas they ignore each other and only register collisions with the ground plane - falling right thru each other...
...although the POP solver's "make objects mutual affectors" is on...
is there a parameter that will cause them to register collisions....---say yes yes yes---
or take the long route: consider them RBD objects until they collide and then switch them over to being squishy...sjoe, even that sentence is uber long!
thanx any pointers...
Hello Suz,
Did u try to bake them out at BGEOS to preserve the squishy feel and then then u can declare them as RBDS objects to get that collision with squishy feel and do u animation?I have tried it but may be it will work for you....
  • 4 weeks later...
