rdms Posted July 11, 2008 Share Posted July 11, 2008 ** originally posted at SESI forums H9.1.179 Win Vista64 SP1 Using COPs, let's say I have a series of images rendered from 100-1000. I want to blur frames 100-200 using the fit expression ( fit($F,100,200,0,5) ) ... then repeat the same process on frames 350-450, 600-700. I want to avoid having to chop this into chunks of frame ranges. Is there a COP that can do this? I'm sure there's an easy way of doing this. Thanks in advance, Rob Quote Link to comment Share on other sites More sharing options...
old school Posted July 11, 2008 Share Posted July 11, 2008 You mean the Size parameter in the Blur COP? I think you have to always bring the value back to zero then add on that: fit($F,100,200,0,5)-fit($F,200,201,0,5) You can turn this in to a function quite easily. You can have isolated areas, holds and adds... fit($F, 5, 10, 0, 5)-fit($F,10,11,0,5) + fit($F,15,20,0,10)+fit($F,25,35,0,10)-fit($F,35,36,0,20) Or just key frame the channel. Is that what you're after? -jeff Quote Link to comment Share on other sites More sharing options...
rdms Posted July 14, 2008 Author Share Posted July 14, 2008 You mean the Size parameter in the Blur COP?I think you have to always bring the value back to zero then add on that: fit($F,100,200,0,5)-fit($F,200,201,0,5) You can turn this in to a function quite easily. You can have isolated areas, holds and adds... fit($F, 5, 10, 0, 5)-fit($F,10,11,0,5) + fit($F,15,20,0,10)+fit($F,25,35,0,10)-fit($F,35,36,0,20) Or just key frame the channel. Is that what you're after? -jeff Hey Jeff, Thanks for your response - does make sense. In the end, I just animated the channels. Rob Quote Link to comment Share on other sites More sharing options...
