iamjaideep80 Posted July 12, 2008 Share Posted July 12, 2008 Hi I am trying to write a Rman Procedural for Houdini. Right now , what I want to do is , take a bgeo file as a argument and scatter points on its surface at render time. On my first step, I was successful putting points on the input geometry points. Now, I am looping thru all primitives and finding there centres to put points. But there are some methods which when I use in my code, aborts Rman and gives this error . imdisplay-bin: Invalid tile header my code is somewhat like this i = 0; FOR_ALL_PRIMITIVES(skinGdp,skinPrimPtr) { UT_Vector4 hairBasePos; skinPrimPtr->evaluateInteriorPoint(hairBasePos,0.5,0.5); cvs[0] = i*0.2; cvs[1] = i*0.2; cvs[2] = i*0.2; widths = (RtFloat)0.1; i=i+1; } RiPoints(numPoints,"P",cvs,"width",widths); the cvs array is set with arbitrary values, just to check if it is working. Even the hairBasePos gives correct values. I printed it and checked. But This code stops with error imdisplay-bin: Invalid tile header if I skip the statement, skinPrimPtr->evaluateInteriorPoint(hairBasePos,0.5,0.5); code works fine, and renders arbitrary points. I thought my skinPrimPtr is not correct and I included cout << "Prim Num : " << skinPrimPtr->getNum() << "\n"; but it shows correct output and renders without any error. Plz Help... Quote Link to comment Share on other sites More sharing options...
